Mortise Size
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=40837
Author:  Chris Ensor [ Tue Jul 09, 2013 11:27 am ]
Post subject:  Mortise Size
How wide do most people make their neck mortise?
Author:  Pat Foster [ Tue Jul 09, 2013 11:39 am ]
Post subject:  Re: Mortise Size
Yep, 3/4" seems to be standard. Martin M/T necks and three CNC suppliers that I know of use 3/4".
Author:  theguitarwhisperer [ Tue Jul 09, 2013 1:11 pm ]
I use the 3/4 tenon.
Barrel bolts are no problem. If you can't find the exact size you can grind the ends a little, you might need to hacksaw the screw slot a little deeper if you do that so you can still get the bolt-hole lined up correctly.
Author:  Casey Cochran [ Tue Jul 09, 2013 2:18 pm ]
For anyone who is having trouble finding the hardware locally- The Lowe's in my town seems to have a better assortment of fasteners than Home Depot but did not know what a barrel bolt was. After much sifting through the hardware drawers, I found what I was looking for. They were labeled as "cross dowels".
Author:  theguitarwhisperer [ Tue Jul 09, 2013 2:48 pm ]
...or just mill the mortise and tenon a little wider to provide clearance. ;)
Sure. If you want to.
Author:  theguitarwhisperer [ Tue Jul 09, 2013 3:20 pm ]
Yup.
I pretty much lay out every guitar as I go.
You can modify the approach to fit the hardware if you want.
Or you can make the neck tenon how you want it and modify the hardware to fit it instead.
It's a very flexible approach.
Author:  Rodger Knox [ Tue Jul 09, 2013 3:58 pm ]
Filippo Morelli wrote:
Best part of not having a mortise. :mrgreen:
Filippo
If you don't have a mortise, where do you stick your tenion? beehive
Author:  theguitarwhisperer [ Tue Jul 09, 2013 5:01 pm ]
Filippo doesn't have a tenon. Or, it's very small. I don't know, I haven't seen it.
